Running with a Zipp 808 FC wheelset. Currently Corsa Speed G+ 2.0 is clearly the fastest rolling set out there at the moment, but ignoring that option due to price x longevity concerns at the moment. Might jump to those later for all-out speed on known TT courses if not hitting targets with current round of gear changes.
With that out of the picture, next in line would be a set of Continental GP5000 tires. AeroCoach shows a 2.4W Crr difference between 23mm and 25mm with wider being faster, but not sure if there's an equally significant aero tradeoff there. From other research it looks like 23m GP4000s II was the prior optimal choice for these rims, with those tires measuring a bit wider at 25mm actual. GP5000s appear to measure truer to size at 26mm actual for a 25mm tire, at least from BRR. So if I went with those it would actually be fairly similar.
Should I let the intangible increased comfort of the 25mm set be the tiebreaker here? Or perhaps run 23mm front/25mm rear? I'm sure there's more than a few of you that have gone through a similar research process regarding this, curious to hear what your experiences were like.
carbenfire: Oct 30, 19 13:01
