Please delete if it was posted already, but I don't remember seeing it over the last couple of days.
Bicycle Rolling Resistance tested the new Schwalbe Pro One TT TLE and it's their new #2 fastest tire ever tested - https://www.bicyclerollingresistance.com/...walbe-pro-one-tt-tle.
I'm curious if the tread might be a bit more aero than the Corsa Speed 2.0 and give it more of an advantage. One other thing to note is the wider tread of the Pro One TT TLE. Both tires measured 27 mm wide on the tester's rim, but the Schwalbe has a tread measuring 32mm vs the Vittoria's 25 mm. One of my (many) flats on Corsa Speeds was on the edge of the tread. Nary a mark on the tread, but it punctured the casing/sidewall and wouldn't seal. It's no secret that ultra thin and flexible sidewalls are needed for low rolling resistance, but having a little bit less of them exposed in the Schwalbe seems like a plus.
Thank you BRR for the continued testing!
