Bar end shifters with Zipp Vuka Alumina 110s
Adding a new set of Vuka Alumina 110s and one of the Shimano bar end shifters that I have won’t seem to install - the right side shifter is finally in place but the left side just won’t slide into the extension (as if it’s too wide). Will these things not accept Shimano bar end shifters?
I’ve loosened the shifter as far as it will go but no go. Any help would be greatly appreciated!
Re: Bar end shifters with Zipp Vuka Alumina 110s [Hammer50] [ In reply to ]
They should fit.
-Check the inside of the extension to make sure there is no lip or bump (shouldn't be).
-Try each of the three parts of the shifter individually (bolt, expander halves, shifter body) to make sure they will fit in (they should).
-When you insert the shifter, hold the two expander halves so they don't push against the shifter body and expand.
ECMGN Therapy Silicon Valley:
