Situation
I've seen some good fit advice here, so I'm looking to see if there's some useful input on some cockpits I'm considering. Currently I'm using a PD 100mm stem, 3T Vola LTD bar, with TriRig extensions undermounted and PD Race cups in the forward position. There are no headset spacers so this is as long and low as this setup will go, which is very low (12mm stack stem and 20mm stack bar).
I feel pretty comfortable in this position. Sitting up on steep hills and through aid stations is enough to stay in aero the rest of the ride. My only difficulty is with holding a shrug position for 5 hours. Not sure if that just needs conditioning or if it's the body position. On bumpy roads my elbows slide forward in the pads, and then I have to slide them back to reposition.
Questions
General advice would be good, but I'm largely curious about some cockpit options I'm considering. I would like to keep the PD stem/bottle, but would like to get the new D2Z extensions which contact the whole forearm for comfort, aero, and style points.Those won't work with an under-mount, so I'm considering these three aerobars, in no particular order. Which would be best for my position (for you fit experts)? And which would be the fastest bar (for you aero experts)?
Option 1: Alpha Classic with bars top mounted at minimum stack
- Fit: This would increase stack by ~10mm and increase max reach by ~10mm
- Aero: Non-UCI, slim profile. Cables would be nicely routed (rear exit) but the extensions aren't in line with the base bar. Is that a slower design due to frontal area or faster due to the gap between the pad and base bar?
Option 2: Vision/Willier Twin Foil OEM Bar (basically the old TFA but with standard bar clamp and wider extension position)
- Fit: Same as current setup
- Aero: Looks UCI legal. Brake cables exit the bottom of the bar, unfortunately. Extensions in line with the base bar. Wider extension position may be good for getting the D2Z set directly under the center of my forearms.
- Other: Would require creativity with D2Z extensions using a collet/clamp, but it should be doable.
Option 3: Felt Bayonet
- Aero: UCI version still looks fast and is easy to find. Cables sit the rear, which is nice.
- Other: Can't find the slim 4.2:1 non-UCI carbon version, but standard aluminum versions are available.
Current fit
Alpha Classic
Willier/Vision Bar
Felt Devox 4.2:1
Questions
Current fit
Alpha Classic
Willier/Vision Bar
Felt Devox 4.2:1
