I just picked up a new set of 2015 Zipps. 404 & 808. What is the max size Conti tires are you using on this year model Zipps?
Re: Zipp Max Tire Width [r-b]
I don't believe that there is a maximum width.
I'm sure I will get tossed to the sharks for saying this, but I had a 27mm Zipp Tangente Speed SL tubie on my 900 disc. As long as it clears the frame, you should be fine but ideally you want to keep it within that 105% rule (https://blog.silca.cc/...ure-and-aerodynamics)
I have run 20-25mm Conti's on them for years.
2024: Bevoman, Galveston, Alcatraz, Marble Falls, Santa Cruz
