s13tx wrote:
dktxracer wrote:
DFW_Tri wrote:
P09 (I hated it-didn’t fit me well but works well for many)
I have a P09 and it gave me headaches due to the fit. There were a few high spots that pressed into my head. I shaved those down with sandpaper and now it's comfortable.
The biggest problem with P-09 is when the visor is down, air comes in through the gap so my eyes get dry. I wear contacts and this really bothers me. It’s not easy to put on either. For the Sprint and Olympic distance, Aerohead is way to go. My T1 and T2 time is usually within 40-50 seconds and helmet helps me a lot. Most of all, when you have head wind, tuck in and you can tell you are getting the aero benefits from the helmet.
Agree 100%. I don't use the visor on the P09 for the same reason. I also use an Aerohead for sprint and Olympic distance because it's quick to put on and the magnetic visor system works very well. I'd use it for longer distances except that the weight kills my neck after around 2 hours. Thus the P09, which is quite a bit lighter.
