Quote:
I'll probably go for the 56 with 90mm stem (profile positive rise) as the 56 was my bikefitter his first choice. After reading a lot of your fitting advice on this forum topic here, I think that maybe I might feel a bit too compressed on a 54. It's just that a lot of internetpeople (I know, they're no professionals) keep telling me to go for the 54. As apparently you can make a smaller bike "bigger", but you can never make a bike that's too big "smaller". So that's just the one thing that scares me.
If you would also advise me a 56 with 90mm stem, then I'd feel 100% confident (as I've read here that your advice is always spot on!).
But there's a promotion going on right now for the X-PR and I'm too scared to miss it! So I might just order and if you would tell me to go for a different size, hopefully I can still change my order 🙈😁
Just so excited to buy a new bike and this promotion is almost killing me 😁
LucyLoes,
I'm so glad you wrote in - and yes, please have a look at David's note (cyclenutnz), he's VERY smart!
Based on your body numbers - you have very long legs for your height - I'm very certian that your Pad Y is close to 690 and your Pad X is ~460.
You should get a size 56 but not because of the "nearness to bottom bracket" - I'm sure there's some logic in that but your fitter and I would have to chat for a while so I could understand their thinking. I want you to do it because the 56 is the best set up for you. Get the 56cm XPR with the Profile Design 90mm stem and set the stem in the -17 degree position (level with the ground). Put 20mm of spacer under the stem and 30mm of pedestal under the aerobar and you'll be at pad Y 690. Then position the arm pads just about dead center of their range and you'll have Pad X of 460. Ride a while - start simply with 45-60-75min rides and get to know the bike, aim for comfort first. You may feel the desire to elongate the cockpit or shorten it - you can easily and have a wide range with this perscription. You may feel like you want to ride lower on the arm pads - you can pull out spacers and go down by 5 or 10mm at a time to find your perfect spot!
Get back to me with questions if you have 'em.
Ian
Ian Murray
http://www.TriathlonTrainingSeries.com
I like the pursuit of mastery
Twitter - @TriCoachIan
