Hed Jet + 6/9 vs. Pre Firecrest 808
Looking for aero data on the Hed Jet + 6/9 vs. Pre Firecrest 808 (2008 or 2009 with aluminum brake tracks (purchased May of 2009 new)).
I am considering replacing my old 808s and with either a Hed Jet+ 6 or 9 wanted to see what aero gains I might pick up.
Re: Hed Jet + 6/9 vs. Pre Firecrest 808 [Stelvio] [ In reply to ]
Probably will be limited data out there directly. You could try to deduce the differences from various data but you will love the JET+ and you can ride wider tires without affecting aerodynamics. Tire interaction is probably going to be where the greatest aero gains are as well
Re: Hed Jet + 6/9 vs. Pre Firecrest 808 [Thomas Gerlach] [ In reply to ]
I saw where Zipp stated when the Firecrest came out that the 404 FC was faster than the old 808.
Hed says the best tire width is a measured 25mm width. Do you know if the GP 5000 measures accurate on the Hed 6/9 + or at least close.
You should use a solid disc wheel on the rear.
Re: Hed Jet + 6/9 vs. Pre Firecrest 808 [jimatbeyond] [ In reply to ]
I use a disc for the rear, its a the older aluminum brake track Zipp clincher disc, older than the 808 front.
The modern Jets are faster....ask me how I know ;-)
I don't even ride the FC 808 anymore...for a reason....
Brian Stover USAT LII
Accelerate3 Coaching
Insta
Re: Hed Jet + 6/9 vs. Pre Firecrest 808 [desert dude] [ In reply to ]
Ok Brian, I'm asking.
I picked up the 6/9 combo, the deal did not include the 9/9. I still plan to use my older disc wheel (Zipp w/ Aluminum brake track) unless its not permitted. Does your statement still stand with the Jet+6 vs. the pre FC 808 in all conditions?
I'd ride the Jet 6 over the older 808 8 days of the week
Insta
Great. Thanks. I know you've done a lot of testing; that is the kind of answer I was looking for.
Do you think I can run a 25 mm gp 5000 on the Hed jets and not ruin the aerodynamics, I am kinda worried because the tubeless gpp 5000 are not available in the 23 mm. they measure about 1.7 or so wider than the brake track... btw i need to sen that suit to you I keep forgetting.
Re: Hed Jet + 6/9 vs. Pre Firecrest 808 [Cookiebuilder] [ In reply to ]
From the FAQ's page on the HED website (underlining by me for emphasis).
What tires/size do you recommend?
28mm actual width for Ardennes and Vanquish road use. For Jet wheels 25mm actual width is the fastest option, but only by a factor of about 3-4 seconds over 40km. Unless a podium step hangs in the balance, 28mm for Jets wheels is a very solid choice. The difference in speed will only work out to approximately .05kph per hour between 25 width and 28 width. Note that we are recommending ACTUAL MEASURED width, not labeled width.
25c 5000TL's, which would presumably be somewhere between 27 & 28 mm wide mounted on a Jet rim, so make of that what you will. I know I wouldn't call 0.15 seconds per mile lost "ruined aerodynamics,"
Care to share what wheels you find interesting for both road an tri?
Hed Jet 6/9 tested faster than Zipp 808 NSW at higher yaw angles. Surprisingly, the former is also lighter. Based on this, I can deduce that the 6/9 is faster than pre Firecrest 808.
Re: Hed Jet + 6/9 vs. Pre Firecrest 808 [RichardL] [ In reply to ]
RichardL wrote:
Hed Jet 6/9 tested faster than Zipp 808 FC at higher yaw angles. Surprisingly, the former is also lighter. Based on this, I can deduce that the 6/9 is faster than pre Firecrest 808.
Thanks Richard. The chart says Hed Jet, do you know if this was the 6 or 9. (I ended up with the 6 for the front wheel due to significant price difference). If you have a link that would be great.
Yes, that was the Hed Jet 6/9 wheelset, and the 808 was the NSW: https://www.youtube.com/watch?v=h0BH3wXzhrI (starting at 11:11)
Tom, chiming in here - have pretty much always raced on HED wheels - Jet 9 up front and for the past three seasons a Jet disc. Before then the rear was a Jet 9 w/Powertap hub and wheel cover. I 'need' a rear wheel other than the disc (qualifying for Kona does have its downsides) and am looking at My Bike Shop and getting their 6/9 combo and then reselling the front 6.
Coaching: https://bybtricoaching.com/ - accepting athletes for 2023
Re: Hed Jet + 6/9 vs. Pre Firecrest 808 [natethomas] [ In reply to ]
Nate that is exactly what I purchased yesterday. Part of the reason is for a backup rear race wheel in the event that there is a last minute prohibition on discs. It happened at Gold Coast Worlds and I believe it almost happened in Rotterdam Worlds too. Then I would also be set should I be so lucky to make it back to Kona when I give Ironman another go. I borrowed a friend's wheels for Kona and IM Cozumel.
Once I locked in on the 6/9 due to the great price difference vs. the 9/9 at this time, I was trying to get a read on the new 6 vs. the deeper old 808.
If I was only looking for a front we could have split the order.
Re: Hed Jet + 6/9 vs. Pre Firecrest 808 [gary p] [ In reply to ]
thanks! so 16 seconds on a full ironman haha, i'll stop worrying
Thanks Richard. That is helpful. The chart also doesn't say Jet + but you can clearly see in the video that it is a Jet +, additionally once you see the 2017 date on the video you would assume Jet +.
