RobInOz wrote:
Mark57 wrote:
RobInOz wrote:
JasoninHalifax wrote:
What glide are you talking about? Good swimmers don’t have a glide.
Swim coaches I know have been focusing on DPS and rate fior a long time. But as the article says, DPS is harder to come by, so it takes more work to make progress on that front.
Maybe I should have said "hand extension". In open water I try to dive my hand in early, without fully straightening my arm.
Hi @RobinOz. Rather than describing the "glide" as a hand extension I think of it more as a shoulder movement. The shoulder shrugs and closes the gap between the ear and the shoulder joint (markedly improving streamlining). The whole arm extends forward which has 2 effects. Firstly the catch can now start from a more distal position and secondly and more importantly the lats are stretched. A stretched muscle gives a much more powerful contraction. As Jason said from the pool deck it looks like the whole arm is just sitting there gliding but in actual fact it it is actively moving forward. I think whoever first described that phenomena as a "glide" has given lots of swimmers the wrong impression.
Yes I'm not very good explaining it using only words. Much easier when you can demonstrate what you mean using your arms.
Agree with the stretched muscle. I try to feel the stretch in my arm pit
In my n=1 experience i felt it helped to envision a big stretch/extension to help getting more streamlined by getting your body less flat and more like a keel of a boat instead of horizontal in the water.
Also good to see your description of the catch up, as that is how i have been using it. Trying to perfect the catch by doing it one at a time, slowing down the pause over time as the coordination of the movement gets better.
Without a partner how much do you all estimate for the wall push off? My garmin stroke rate numbers are quite low, but that reported value us just total strokes divided by total time. Either way, my low hanging fruit is my stroke rate, but i did slow mine down a bit from last season but gained dps so i am faster by about 3 to 5s per 100y.
