BigBoyND wrote:
Wow, so a pro3 is faster than a 100mm wheel if yaw stays below 10deg.
Does the HED H3+ test faster or slower than the Pro3? I'd be curious to see a how the H3+ with 23mm tires stacks up.
Btw, how do you weight drag in your charts? Equally for each angle?
No it’s the opposite - the TITAN is faster than the Pro3 at lower yaw angles as the drag is higher. At greater than 10deg the Pro3 is faster (lower drag - red line) but the weighted average makes them very similar, within around 1w using the tyres stated.
The weighted average is on our website under the AEOX disc data page, click on Aero Testing Data and then the AEOX disc vs a Super 9 etc and there’s a full explanation of how we set up our wind tunnel experiments (with photos). You definitely don’t want to take a straight average over the whole lot.
AeroCoach UK
http://www.aero-coach.co.uk
