BLeP wrote:
slowguy wrote:
BLeP wrote:
slowguy wrote:
You could, but you’d have to individually address each crime that you wanted to have a higher penalty read is that this law was designed to add penalty for any crime, if you committed it with a firearm.
The remedy is to pass an updated law with greater specificity. However, that’s not really the immediate issue. The issue is that potentially any conviction involving this law over the past 33 years now has a constitutional challenge
Yup. That what shitty law writing does, it leaves the door wide open to challenges.
5 Supreme court judges feel that the law is poorly written.
Fucking Dems (and one of the GOPs hand picked guys but we won't talk about that too much because this is clearly the DEMs fault) ruin everything.
I’m not saying the ruling is incorrect. It might be perfectly valid. I’m just saying that it raises some problems, and it’s not as easy as just raising penalties on other existing laws, as the previous poster suggested.
Yeah, it's not ideal. Are you suggesting that should be a reason to not rule this way? Or merely pointing out the elephant in the room?
I was pointing out that simply raising sentencing on crimes like armed robbery isn’t really so simple, and that it doesn’t address the larger problem that arises from the ruling, which is all the previous convictions.
Not arguing that the ruling is incorrect just because it may be painful.
Slowguy
(insert pithy phrase here...)
