bespoke wrote:
Injecting new life into an old thread
Does anyone know if you can add spacers to the pads? I was told not; which seems crazy because I think in its normal road position the pad height will be very low
The only spacer available is the pad wing spacer which raises them +5mm (part number W327606). Other than that, you would want to check your fit measurements to make sure you have your bar stack correct as you can add/remove headset spacers or change the stem to the High stem if you have the Low stem.
Mitchell Mathews | Community Manager | Trek Bikes | @mitchmathewz
