rruff wrote:
You are sliding forward primarily because you are using your glutes and hamstrings (force pushing back late in the stroke). These are strong pedaling muscles, but I think the "tri norm" is rely more on the quads, hence the relatively tall forward saddle position, and hips rotated forward. Plus you are pedaling way too fast... what's up with that...? ;)
Things that open the hip angle (torso/thigh angle at the top of the stroke):
Taller saddle.
Forward saddle.
Hips rotated back.
Shorter cranks.
I'm agnostic regarding whether moving the saddle back is "better" than where you had it originally. I suspect you are trying to preserve that hip angle, if you want to rotate your hips and flatten your back, a rearward saddle isn't going to help. It *is* better for taking weight off your arms, but you can solve the shoulder strain issue with proper reach and front end posture. The experts claim that forward rotated hips are the way to go, so...
Do whatever is necessary to make forward rotated hips comfortable and relaxed. Don't worry about pedaling and power output (yet)! Your pedal stroke will need to change.
Not sure if the comment about cadence was sarcasm or not. My cadence is normally around 85-90 rpm as it was when I filmed the video.
I've read your post a couple of times now and I'm struggling to pick up on what you're suggesting.
Are you suggesting that when I press lower to force a flat back, that my hip angle is too tight (Bike is not ok, changes need to be made to open up my hips when low)?
That I need to practice the new posture more to make it natural (bike is ok, hip angle is ok when low and it's just me that needs to get used to the new position)?
That the "right" position will put me into the correct posture with a flat back naturally (hip angle is ok when low, but there's another bike position that will get me there without relearning how to hold my upper body)?
If it's hip angle too tight, which of the 4 things you mentioned would you recommend playing with first?
Taller saddle. Given the ST anthem of "your saddle is too high!" has made me afraid to raise it. I'm ok to do this if the ST police are ok with it. I feel like I'm a natural toe pointer and I don't see a lot of ankle motion when looking at the videos, so maybe a little would be ok?
Forward saddle. I'm open to sliding the saddle and cockpit forward together.
Hips rotated back. Seems like this is the problem I'm trying to eliminate.
Shorter cranks. This seems to be the new ST anthem (your cranks are too long!) Hardest/most expensive to change (currently using a quarq and don't really want to change due to costs).
