I can't find info on this seat post head anywhere.
It's a two bolt system. It has a front bolt that is a dial down with a head that is the size of a nickel and you finger tighten it or use pliers to snug it up. The rear bolt is standard and pulls down/against that front bolt's position.
But, no matter how low I dial that front bolt down, even when I max it out as low as it can go, the back bolt rotates the bottom plate when I tighten it to torque specs.
This causes the saddle to rotate counter clockwise and the nose tilts up. It's an ISM saddle and I want the rails level.
What am I doing wrong here? Can you give me any tips on this seat post head?
"Outwork your talent." Kevin McHale
