New Force 1 derailleur (replaced an Apex 1), new cable. Bike has less than 500km on it. So the cassette, chain are good as well.
Adjusteded my limit screws.
Adjusted the B screw to get the pulleys as close as possible.
The problem seems to be the cable tension.
I can get it to shift relatively well in either the top gear, or the low gears, but not both.
I adjust the tension for one end and other end shifts poorly or skips gears.
My best guess (and I'm a mediocre mechanic), is that the housing from the chain stay to the derailleur is too short causing the cable tension problems?
The rest of the routing from the shifter to the chain stay is very clean with no major bends.
My other other Force 1 bike has always shifted like a dream and it's housing is probably 2 inches longer.
Ideas?
Ideas?
