NordicSkier wrote:
Sidewall cut this weekend. Sealant is useless, but the cut isn't that big.
Should be no problem to fix with a bank note, a tube and some air right? At least it will get me home to replace the tire.
Valve out, tube in, bank note in place.
After 25min and covered in sealant, I cannot get the tire back on the rim, even with tire levers.
My wife was not amused at having to pick me up.
I'm going to give road tubeless another shot, but if this happens again, I'm back to latex tubes and non-tubeless tires.
I've scanned the thread quite a bit, but couldn't find what wheel you're using? Saw that the tire is IRC Roadlite 25c. Just curious on the wheel.
At first glance, it sounds like it might be a wheel issue. I say that because I remember a few years back, every wheel manufacturer was recommending IRC or the then-new Schwalbe One as the best-fitting tubeless road tires (I want to say they had both figured out an Aramid tire bead that worked tubeless... while Hutchinson was still the biggest tubeless player and using their SUPER stiff carbon beads). There's
another thread going on now about a tire fit issue on a (Reynolds) tubeless wheel... which we've seemingly narrowed down to the wheel as the issue, and won't seem to work even with common tube-type tires.
The thing from this thread that puzzles me is the seemingly common problem of pinch flats. I honestly think I've had maybe one ever. Are people running SUPER low pressure, or just not pumping up every ride? I run 23mm tires at about 100psi, 25's at ~85, 28s at ~70, and 32s at ~60. Note those are all actual measured tire sizes, because wide rims really change things (i.e. 23mm labeled tire on a fat rim might inflate to 25-26mm). I'm close to 200 pounds, no tube pinch flats.
