Enve 3.4 disc wheelset, Campagnolo Super Record 11 EPS V3 hydraulic groupset, 3T handlebars, 130mm Most ultra-lite aero 1k Di2 stem, Sram Red exogram crankset 172.5/130bcd, Sram Red 22 hydraulic shifters and calipers
1. Campagnolo Super Record EPS V3 complete groupset 2500/OBO
2. 3T Superergo LTD stealth bars 200/OBO
3. 3T Aeronova LTD stealth bars 250/OBO
4. Sram red exogram crankset 172.5/130BCD 200/OBO
5. 130mm Most Unltra-lite 1K Di2 stem 170/OBO
6. Sram Red 22 Hydro R hydraulic shifters and post mount calipers 600/OBO
1. Campagnolo Super Record 11 EPS V3 hydraulic groupset. 2500/OBO
There’s a small scuff on the bottom of the right shifter lever, close up of the scratch is in one of the pictures.
Here’s everything that is included:
Crankset is 52/36, 175mm arms with Campagnolo’s ceramic CULT bearings that are freely spinning and no where near needing to be replaced. Teeth are in perfect condition.
Cassette is a Super Record 11/25, teeth are still perfect, and I’ll include a new Campagnolo Record 11 chain.
Super Record 11 EPS front derailleur, Super Record 11 EPS rear derailleur, Campagnolo H11 hydraulic shifters (same as Super Record shifters just the hydraulic version), Campagnolo H11 calipers designed specifically for 160mm rotors, Campagnolo 160mm centerlock rotors.
Battery and EPS V3 control module and I’ll include an eps cable extension set for larger bikes that need longer cables.
Also included is the EPS charger, magnet strap for powering the system off, and the Campagnolo specific brake bleed kit.
This groupset came off of a 59.5 pinarello with a 130mm stem and was internally routed though the bars and frame so there should be plenty of hydraulic hose left for a larger frame without needing to replace the hydraulic hose. They will obviously need to be bled after installation since cutting of the hydraulic lines, close to the calipers, was necessary to remove them from my bike. They use magura barbs and olives and any bike should have them for a couple dollars.
2500/OBO
[url=https://ibb.co/BVQYp2x][/url]
[url=https://ibb.co/5nSw6LV][/url]
[url=https://ibb.co/fqvzgdj][/url]
[url=https://ibb.co/QpZZnDT][/url]
[url=https://ibb.co/G7Gfzvg][/url]
[url=https://ibb.co/BfKn2sP][/url]
[url=https://ibb.co/hsP4tZb][/url]
[url=https://ibb.co/WncZnfm][/url]
[url=https://ibb.co/n6Jh0W1][/url]
[url=https://ibb.co/9yNnHcs][/url]
[url=https://ibb.co/BzBmNZZ][/url]
[url=https://ibb.co/M8P62pw][/url]
[url=https://ibb.co/0YSrVp3][/url]
[url=https://ibb.co/Y8WD6z5][/url]
[url=https://ibb.co/ChD3HV5][/url]
[url=https://ibb.co/1mPbjgw][/url]
[url=https://ibb.co/qnj3C4v][/url]
[url=https://ibb.co/d4yHY9P][/url]
[url=https://ibb.co/ZLMmkHZ][/url]
[url=https://ibb.co/K77K8DG][/url]
[url=https://ibb.co/CMygmNT][/url]
[url=https://freeonlinedice.com/]online coin tosser[/url]
2. 3T Superergo LTD stealth bars 42cm, scuffs around where the stem faceplate clamps on and a little mark to the right where my K Edge garmin mount was. Small hole drilled on the backside for internal wiring to hide eps control unit in the stem. Bars are setup for internally routing brake and shifting cables/hoses.
42cm C to C at hoods, 44cm C to C at drops, 77mm reach, 119mm drop, 180 grams
200/OBO
[url=https://ibb.co/YXh6RnP][/url]
[url=https://ibb.co/LPmKSxQ][/url]
[url=https://ibb.co/bH9ZXX4][/url]
[url=https://ibb.co/m8nVnSC][/url]
[url=https://ibb.co/vw0Dczq][/url]
[url=https://ibb.co/y43bdsV][/url]
[url=https://ibb.co/KWhcqV1][/url]
[url=https://ibb.co/Z8dzdLb][/url]
3. 3T Aeronova LTD stealth bars 42cm. Perfect condition and scratch free. Maybe 100 miles on them they just weren’t for me. Small hole drilled on the backside for internal wiring to hide eps control unit in the stem. Bars are setup for internally routing brake and shifting cables/hoses.
42cm C to C at hoods, 44cm C to C at drops, 104mm reach, 127mm drop, 225g
250/OBO
[url=https://ibb.co/1KqnGRy][/url]
[url=https://ibb.co/w4Qcr74][/url]
[url=https://ibb.co/GQY2fYG][/url]
[url=https://ibb.co/JqysCTt][/url]
[url=https://ibb.co/vm3gcnN][/url]
[url=https://ibb.co/fYWrTrz][/url]
4. Sram Red Exogram BB30 crankset, 130bcd, 172.5mm arms. Those are 1x chainring bolts pictured and they aren’t included, I’ll try and find the 2x ones in my parts bin.
200/OBO
[url=https://ibb.co/2nDFWPc][/url]
[url=https://ibb.co/mSPwWy1][/url]
[url=https://ibb.co/H2n7Tt1][/url]
6. 130mm Most ultra-lite aero 1k Di2 stem
170/OBO
[url=https://ibb.co/L1Vy6xm][/url]
7. Sram Red 22 hydro R hydraulic shifters and post mount calipers. Like new, without a scratch on them, came off a bike with less than 100 miles on it. You will need new shifter cables/housing and the brakes will need to be bled after installation.
600/OBO
[url=https://ibb.co/YyX0VbS][/url]
[url=https://ibb.co/nm3bPXg][/url]
[url=https://ibb.co/YPNt4pW][/url]
[url=https://ibb.co/gwjVBpp][/url]
[url=https://ibb.co/0JMvFn9][/url]
[url=https://ibb.co/GtRrqHH][/url]
[url=https://ibb.co/sJxHFXC][/url]
[url=https://poetandpoem.com/...t-love-by-john-clare]what is the meaning of first love[/url]
Re: Enve 3.4 disc wheelset, Campagnolo Super Record 11 EPS V3 hydraulic groupset, 3T handlebars, 130mm Most ultra-lite aero 1k Di2 stem, Sram Red exogram crankset 172.5/130bcd [strongbear0] [ In reply to ]
Bump
Bump
Bump
bump
TTT
TTT
Bumpity bump
TTT
