Hi,
I have an old TT Bike I use for my Tacx Neo, it has a 54/40, 11/28 setup.
I am a bike maintenance novice but somewhat handy
When I am in the big ring and I shift up to the 3rd smallest gear it jumps back to 4th. I can’t get it to go higher without noises and jumping
I took The bike off, put it on a stand with 11/28 rear wheel and adjusted everything so it worked great and shifted fine on the stand
When I put it back on the Tacx same problem. Also when I’m in small chainring and 28 tooth it seems to rub a little. It’s almost like the cassette needs a spacer to shift everything a bit to the right
When I try adjusting the DI2 on the trainer I can’t get it right. Sorry if this isn’t clear but any help appreciated
Animalmom2: May 12, 19 20:19
