has anyone had a blipbox port go bad? i’ve always had the blips on the aerobars plugged in to the same ports and just recently added blips by the brakes. seems as if one of those previously unused ports is dead. i’ve tried to replace the battery and resync everything but no luck. has anyone had this happen before? is there a solution?
Re: etap blipbox issue [lhmd21]
If you plug a previously working shifter into that port, does it work then?
Re: etap blipbox issue [nickwhite]
nope, any time i move a working blip into that specific port, the blip does not work
lhmd21 wrote:
nope, any time i move a working blip into that specific port, the blip does not worksounds like that port is fried. I would pursue a warranty. If it's not under warranty, I'd get some q-tips and isopropyl alcohol and see if I could clean it into working again.
nickwhite wrote:
@lhmd21 - any luck getting the ports to work? I've having the same issue, cannot get any warranty assistance (bought the bike used from The Pro's Closet), and the SRAM Red eTap BlipBoxes are very difficult to come by. I was toying with taking the box completely apart and trying to see if I can fix/replace the 2 dead ports.
