Tubeless Repair kit for race
New to the tubeless game, but pretty clueless on the best setup for keeping a flat kit for a tubeless disc wheel. I'm a minimalist when it comes to flat kits, especially for races. Any suggestions?
Re: Tubeless Repair kit for race [onceatriathlet3] [ In reply to ]
For in-race repair, use a tube (basically same flat kit as a tubed setup). Basically convert it back to a tubed setup. Make sure to have a tire boot (gel wrapper works in a pinch), since a significant cut that the sealant can't handle is one of the key flat causes.
ECMGN Therapy Silicon Valley:
Tape this under your saddle:
For Road / TT / Tri: Fastest means to plug and fill a tire. Only uses the smaller of the 2 plugs, which is fine for 99% of road damage.
Dynaplug Air
For MTB / Gravel: Has both the smaller and larger plugs, but you'll need a seperate air-source.
Dynaplug Racer
I talk a lot - Give it a listen: http://www.fasttalklabs.com/category/fast-talk
I also give Training Advice via http://www.ForeverEndurance.com
The above poster has eschewed traditional employment and is currently undertaking the ill-conceived task of launching his own hardgoods company. Statements are not made on behalf of nor reflective of anything in any manner... unless they're good, then they count.
http://www.AGNCYINNOVATION.com
Re: Tubeless Repair kit for race [xtrpickels] [ In reply to ]
This is awesome. Had no idea it existed. I've always just said a prayer before racing on tubulars.
How's the length on that insertion tool? Would you be able to fit it far enough into a 23-25mm tubular to inflate with out damaging the side opposite the puncture?
x2 on dynaplug, can be back up riding super fast
