It was time for some maintenance so I tried cleaning the DA 9100 pulley wheels for the first time using the procedure BBInfinite has on their website for their pulley wheels.
- remove screws
- take out pulley wheels
- wipe them down
- take off the plastic bearing covers
- rinse with isopropyl alcohol
- let dry overnight
- put a a drip at a time of Rock'n'Roll chain lube from each side and spin until it spins nicely
- put the plastic covers back on
- reinstall with fresh loctite on the screws
Bottom pulley spins nicely. Top barely wants to rotate at all unless I use very little torque, less than the range recommended by Shimano.
Shimano manual calls for 2.5 to 5 Nm. First I tried 4 Nm and the top wheel jammed up. Then started over and used 2.5 Nm. Still jammed up. At 1.5 Nm it spins okay, same as before cleaning, but I wonder whether there is a part that got lost since even 5 Nm should work and I wouldn't expect friction from pressure on the plastic covers. All four plastic covers look the same so I don't think those can be mixed up. Aside from that there are no sleeves, spacers, covers, etc. unless something got lost in the removal. Bottom jockey is torqued to 4-5 Nm and it's fine.
Has anyone else experienced this?
- remove screws
- wipe them down
- let dry overnight
