mdtrihard wrote:
What is a "pull set"? Paddles with buoy?
A pull set is any set where you use the pull buoy between your thighs or ankles, and hence do not kick. You can pull with paddles or w/o. When you swim w/o the buoy and hence are presumably kicking at least a little, then you are swimming "full stroke", but most swim workouts don't usually say that but rather just indicate pull sets and kick sets, and then everything else is full stroke. Kicking w/ or w/o the kick board is a kick set. Also, a "set" refers to two or more swims; each swim within a given set is called a "repeat" or just 100, 200, or whatever distance you're repeating. A set does not refer to one swim though many STers seem to think it does, e.g. 10 x 100 free is a set with each 100 being a repeat, vs doing a 500 free for time is a swim or time trial, etc. And then 2 x 500 would also be a set. Also, a "ladder" is considered a set, e.g where you go 50-100-200-300-200-100-50 and try to hold the first 50 pace for the whole set. A ladder can go as high as you want and include various increments, e.g. 50-100-150-200-250-300, then back down.
"Anyone can be who they want to be IF they have the HUNGER and the DRIVE."
