tanzbodeli wrote:
I'm a relative novice, but it doesn't seem to be expected that your run pace/fitness would necessarily decrease because you are taking on swim and bike training. To me, it sounds like maybe an overtraining issue. If you're adding a relatively heavy load of bike training, your legs might just be too fatigued to perform as you expect on the run.
I started structured bike (and swim) training in the fall, and my run pace has only
improved, in spite of reducing my run volume. I was never a high volume runner, but I used to average 2-3 runs per week for a total of ~15 miles. My typical 5k pace was in the 6:50-7:00/mi range. Since I started bike (2-3 times a week) and swim training (3-4 times a week) in October, I've reduced my runs down to 1-2 per week. I'm running faster than I ever have before. Sure, it's n=1, but I think in general if you're not overtraining and you have a decent base of run fitness, adding in bike and swim, should improve your run fitness.
You are incorrect about assuming that your run pace will necessarily improve by bike training.
If you are a novice runner, then sure, nearly anything you do added with your legs will help - cycling, jumping, skiing, basketball, etc. mainly because your level of performance and expectations are nowhere near your potential.
However, if you have a decent level of prior run training regular volume and speed, if you do not maintain that level of run training (because you are cycling a lot more), you will take a hit on your running compared to your prior performance. You can minimize the hit to running by doing a lot more biking to compensate, but at some point not too far along, you will have to run more to improve running rather than hoping for bike x-over.
The OPs description is exactly how I felt after following the Trainerroad Oly Build plan, which I've posted about on other threads, but I really feel is too hard for its own good. There are zero easy rides, and three hard rides per week - one VO2max crushingly hard workout, one hard steady state workout, and one long but surprisingly punishing long 90min ish SS workout. The run used to be my strength, but after the TR cycle, I was unable to run anywhere near my normal (modest) training amount due to the bike beatdown, and I lost more on the run than I gained on the bike on race day. (Not to mention swim losses...)
Consider yourself lucky if you can run 1 day per week, bike the other days, and pull off sprint/Oly runs in the sub7:00/mi range, unless you were a decently good runner beforehand.
