MEN'S GEN II ELITE AERO SHORT SLEEVE TRI SUIT - WHITE/BLACK
SIZE MEDIUM
$200 OBO
SIZE MEDIUM
$200 OBO
- NEW AERODYNAMIC SLEEVE CONSTRUCTION: New sleeve design provides maximum aerodynamic upside with minimized seam construction and strategically taped edges that reduce “sausage-arm” effect with a laser cut.
- EXPANDED AERODYNAMIC MESH PANEL: This ROKA suit has a full aerodynamic mesh back panel that reduces seams, and aides thermoregulation; Aero Mesh + Coldblack treated fabrics keep you cool.
- DUAL, QUICK-ACCESS SECURE POCKETS: Dual stretch pockets securely hold gel flasks and nutrition on the bike and run—designed and tested in the as-worn position for quick, safe reach and access.
- ELASTIC INTERFACE, LOW PROFILE CHAMOIS: Elastic interface, single-density, low profile foam chamois moves with the body and doesn’t sacrifice long distance comfort—it conforms, protects and moves with you on the bike and run - no diaper butt!
- NEW LASER CUT LEG: Premium double knit fabric featuring clean compression with a laser cut finish. Strategic silicone print to eliminate “sausage-leg”, and aerodynamic upgrade.
