I'm buying my first legit tri-bike (Specialized Shiv)...so next step is to upgrade the wheels
Budget: ~1k
Brakes: Rim
Use: Primarily Triathlon, could use on road bike as well. Hilly terrain likely (IM Canada this year)
Considerations: I'm a mediocre bike handler plus the hills, so thinking 45-60mm depth max to be conservative? Also given hills and budget I'm thinking an Alloy brake track will be a solid pick
Top choices I've found:
https://mybikeshop.com/...ro-carbon-black.html - Seems to tick all the boxes
https://mybikeshop.com/...4-plus-wheelset.html - Essentially same price once you factor in the tires and Cassette. Could also do Jet+ 4/6 or just the 6 for the same price.
Does the wisdom of Slowtwitch have any advice here, or other options to throw in the mix? My searching can only compare much older generations of these wheels. I'm generously a MOP athlete if that matters at all...
Budget: ~1k
Brakes: Rim
