OLD STYLE PROFILE DESIGN T-1 VIPER aero bars and aluminum aero pad base. What I need the most is left (or both) aluminum pad base. See pic, note how the base sweeps back on the outside AND curves up on the inside. The newer models are straighter on outside and inside. In the pic, there are a few more holes than original (I drilled them to save weight causing the base to crack, my bad). I could also use carbon bars for spares. I could use incomplete set. I do not need the actual pads. Cheap. Does someone have these old bars/pad base sitting around? Thanks
Classifieds
Re: want to buy, PROFILE DESIGN, T-1 VIPER, OLD STYLE AERO BARS AND PAD BASE [coyote pelon]
bump , someone must have some of these things. help
