IamSpartacus wrote:
Dimm wrote:
desert dude wrote:
lightheir wrote:
I did everything. I tried hard as I could to not quit for the first month of it, figuring I'd acclimate. When I didn't I bumped down the FTP. But not too much. THen I started turning it down, 5, even 10%. That worked for awhile, finished the Oly base. But then I started the next TR Oly build block, and the whole cycle repeated again until I was pretty totally beatdown by the mid-late stage of the plan. Pulled the plug at that point.
Honestly, even if I'd turned the FTP down a full 30 watts, ..............mainly because I wasn't crushed from all those darn bike intervals.
I only read a few posts back. Sounds like a few things
1. poor program design bc it crushed you for everything else
2. you estimated FTP was way too high. This is pretty common. For instance I was talking with an athlete the other day who thought their FTP was about 275. I told them it was closer to 250. it can be deflating. ultimately most people would be better off underestimating FTP by 15w than over estimating it by 5w.
3. erg mode
4. you gave it too much time to acclimate. If you still struggled at 5-10% below your best bet would have been taking an easy week
5. too many intervals. Folks and I've said this before: more intervals isn't more better
I read this thread carefully, including Brianâs comments above, as I had very similar experiences with the TR Olympic mid volume plan this year. The base program seemed well structured and reasonably challenging, the bike part was mostly sweet spot with some small injections of short sprints and vo2max. Very reasonable.
However when I moved into the build phase, I started grudgingly questioning the logic of the bike program. I very much respect the TR team, their excellent podcast and the really polished software - so questioning the design of this training plan was a gradual and almost subconscious process. I could just barely finish some of the workouts - and some of them now left me completely gassed, even when I adjusted the intensity down a bit for some intervals. Well, every week it is always one tough VO2max workout, one workout with long intervals usually at 108% (likely overinflated) FTP, and one long ride. And then the specialty phase was even worse - even more grueling VO2max workouts every week, long intervals at 105% (again, likely overinflated) FTP, and a more reasonable long ride a bit below FTP.
I may be missing something, but where is specificity in constant VO2max and above FTP intervals? Maybe this could be relevant for draft legal professional Olympic triathlon, but I doubt that the pros are the target audience of the TR plans. Out of curiosity, I recently downloaded a trial version of Sufferfest to check out their Olympic plan, and while their plan unsurprisingly also includes a fair bit of intensity, many of their suprathreshold intervals are shorter, they also have easier workouts and over and under intervals, some of the intense workouts themselves are shorter, and they have weeks with significantly reduced volumes which is not the case with TR. The Sufferfest plan overall is shorter and less polished, the swim and run workouts sometimes look like an afterthought and I find the whole Sufferlandia theme somewhat annoying. However I suspect that their bike program might be more effective because at first glance it has less overall volume with long intense intervals, allowing for more appropriate training load and a higher chance of recovery and super compensation.
This is not TR bashing at all, I will likely stick with TR as I like their overall concept and style a lot. However I must say that Brianâs points above (especially poor program design, too many intervals) seem to be correct for this specific plan. In the ideal world I wish Chad and the team could pay attention to this thread and make some changes. Or alternatively explain why my take is wrong.
Dimm
Everything x2
Burned out on oly bike program last season.
Made very good gains in sweet spot base and build with high volume during lockdown but this time moved on to v02 once a week, One sweet spot workout and one long ride, the rest easy. Thatâs doable to allow progression and enough energy for the run and swim side of things
Likewise love trainerroad but would
Like to hear from them as to what went on with designing the programs.
Not a sound from TR. I wonder why...
