Just posted in the official Shiv thread, but then some googling led me to this
https://www.specializedconceptstore.co.uk/...19-shiv-expert-disc/
Most of the existing Shiv's are sold out in the store...does anyone know if a launch of more reasonably priced Shiv's is pending? Specs are shown...here's hoping there's a mechanical option as well!
FRAMEFACT 11r carbon, FACT IS construction, crosswind-optimized airfoils, 1-inch lower bearing, OSBB, Fit System, Integrated Nutrition and Hydration Fuelcells, disc brakesFORKFACT 11r carbon, integrated Fit System, flat-mount disc, 12x100mm thru-axleFRONT WHEELRoval C 38 Disc, carbon, tubeless-ready, 38mm depth, 24hREAR WHEELRoval C 38 Disc, carbon, tubeless-ready, 38mm depth, 24hINNER TUBESTurbo Ultralight, 48mm Presta valveFRONT TYRETurbo Pro, 60 TPI, folding bead, BlackBelt protection, 700x24mmREAR TYRETurbo Pro, 60 TPI, folding bead, BlackBelt protection, 700x24mmCRANKSETShimano Ultegra R8000, HollowTech 2, 11-speed, 52/36TBOTTOM BRACKETPraxis, BB30 for ShimanoFRONT DERAILLEURShimano Ultegra Di2 R8050, braze-onREAR DERAILLEURShimano Ultegra Di2 R8050, 11-speedCASSETTEShimano Ultegra R8000, 11-speed, 11-28tCHAINShimano Ultegra, 11-speedFRONT BRAKETRP TT hydraulic levers w/ flat-mount caliperREAR BRAKETRP TT hydraulic levers w/ flat-mount caliperHANDLEBARSSpecialized Shiv Aerobar, carbon, variable stack adjustTAPES-Wrap Roubaix w/ sticky gelSADDLESitero Expert Gel, hollow Ti railsSEATPOSTShiv Carbon, 0mm offsetPEDALSNylon, 105x78x28mm, loose ball w/ reflectors
As with any product, specification is subject to change without prior notification. You are advised to confirm current specification before buying.
