My Wahoo Tickr HR monitor keeps dropping from Zwift. It will sync fine and work for a while and then just drop it's connection. Usually I can just unclip and reconnect the strap connection and it will resync, but just temporarily.
It did this when I first started using it a few months ago, but then I realized that the Bluetooth speaker I was using right next to me was apparently causing interference?......as when I moved the speaker to the opposite corner of the room I stopped having connection issues...and this lasted and was working fine for a month or so. Now I have the same problem back all of a sudden (made no changes). I did replaced the Wahoo Tickr with a new battery just in case. I have my Bluetooth speaker as far way as possible in the room I'm using (about 10 feet away). Any possible solutions to fix this? Can I use a different HR monitor with better results?
Setup is Zwift thru an iPhone and cable mirrored to TV. Elite Direto trainer.
Bluetooth speaker is being connected thru a separate device (iPad) - both are 10 feet from my trainer and phone.
