Trying to discern what to emphasize when cycling: weight, aero, when to put out some extra effort or not, etc.
Aero has been trumping weight for some time now. Yet weight is still a factor or a fraction of a factor. And when to put out an effort has value too because it's harder if you get dropped during a group ride. Which gets us back to aero because the benefit of sitting on a wheel is aero.
http://bikecalculator.com/
https://www.omnicalculator.com/...impulse-and-momentum
In a time trial world, even efforts while being as aero as possible requires fewer watts. And if I can't sustain the higher watts required to go faster then I might as well not speed up in the first place.
Weight plays a greater role in the herky jerky world of road cycling. Whether it's a fraction more of effort to stay with the aero benefit of staying on someone's wheel, then you have little choice to go hard when they do IF you can sustain the higher watts that the person in front will be subjecting you to.
In closing, the main reason I get dropped is because I can't sustain the higher pace that others can ride at. The secondary reasons are that I couldn't put out the effort needed at the moment and I could always be more aero.
It's interesting that there isn't an "aero" component on the impulse and momentum calculator. They consider mass/weight without considering the shape of the mass???
Indoor Triathlete - I thought I was right, until I realized I was wrong.
