The answer sounds obvious but my Schwalbe Pro One 25mm tires measure 26mm wide on my Enve 7.8 SES and 28mm on my Roval 321 disc. I pressume that I should use the actual width (26/28) when calculating pressure tires?
According to CyclingApps Exact Tire pressure I should run the following pressure on my tubeless setup with the difference width:
25mm - 80 psi
26mm - 74 psi
28mm - 65 psi
Any thoughts?
http://www.triallan.com
Ambassador of:
Quintana Roo - https://quintanarootri.com
Bioracer
Precision Fuel & Hydration
25mm - 80 psi
26mm - 74 psi
28mm - 65 psi
Any thoughts?
Ambassador of:
Bioracer
