Moonrocket wrote:
Wouldn’t flipturns in swimming count as a weight bearing activity? Just in a different plane?
I swam in college then got into extreme sports where I broke a few bones. Based on that my doc sent me for a bone density test to double check. The results came back that my bones were significantly denser than average for my stats. I would think all of those high speed flip turns contributed.
Good question:
Flip turning does provide
very mild eccentric loading, but technically not weight bearing because we "weigh" very little in the water; All things considered I'd say not really. Think about it a little more: Water is nearly 800 times denser than air. Also, astronauts use water to to mimic conditions in space (to which they lose massive amounts of bone in space). Between initiating a turn, at
best while moving at 4 mph, changing direction, and hitting the wall, the water and direction change would cushion/decelerate any potential for
significant eccentric loading to make a huge contribution to bone density. On land gravity accelerates our motions more that air can slow us down, plus what ever external force you provide has much greater potential for gains in bone. You probably get more whole body impact and eccentric loading jumping up and down on mattress or a trampoline, not to mention you can get a lot more of it in in the less time compared to swimming 4-5k short course everyday. You'd need to do more flip turns than our stomachs can handle to equate to the same amount of forces experienced from a 5k jog or a solid leg day in the gym.
That doesn't mean that your genetics, swimming,
diet, not smoking and other activities in your life didn't lead to a higher bone density. It certainly could have contributed, but it's less likely that swimming is as much of a contributor to your bone density than other factors may have been.
I would like to point out that, to me, "extreme" sports = greater chance for broken bones, no matter how dense they are. My bone density is in the 99th percentile (via dexa scan), and I have still broken a few bones over the years, not doing extreme sports (In fact the stories are pretty boring unfortunately).
This is all ignoring the fact that the upper body need eccentric/high loading forces just as much as the lower body, and swimming flip turning or not again will not contribute even close to other activities.
Matt Leu, M.S. Kinesiology
San Pedro Fit Works, Los Angeles, CA
Endurance Athlete and Coach
Consistency/time=results
