michael Hatch wrote:
I was being a bit "thick" when I read over this the first time, I sort of thought to myself, there must be two kinds of EPO. But reality sunk in later.
Never thought I would have a situation where I would consider taking a PED. But then again, it ain't cheating if it saves your life, I guess.
All medicine to avoid the effects of altitude in the mountains are PEDs!!!
What is that talk about regarding "saves your life"? Your are trekking in the Khumbu not climbing an 8000m peak. Plan enough time and a flexible schedule (and mind) and just don't push up when feeling bad. Thousands of people do it every year just fine without altitude tents to prepare. Sure some of them get altitude sick but most of them are also on "Everest base camp trek in 10 days"- schedules which are just stupid without prior experience.
And I truly beliefe, from experience, that being fit helps a ton. That is the "having a big aerobic base" kind of fit not the "crossfit type" of fit with lots of high intensity. You want to use the fitness to keep the intensity low while recovering better. That will help the adaptation. If you use the fitness to go high quicker than it will lead to trouble. So instead of doing intervalls with a mask on maybe better spend a couple solid hours trailrunning/hiking in zone1.
I personally really like to leapfrog during the akklimatisation and always sleep a bit lower than the highpoint of the day but that requires enough fitness to do longer days than just from village to village and still recovery enough. Also it is just way more fun to do stuff every day instead of just slogging along for a few hours a day and then sit in a teahouse.
For example above Namche you could do:
Sleep 3600m - Highpoint 4600m - sleep 4000m
- highpoint 5000m - sleep 4400m
- highpoint 5400m - sleep 4800m
instead of the typical
sleep 3600m - sleep 4000m - sleep 4400m - sleep 4800m without ever going higher that day than the stopping point.
