Dr_Cupcake wrote:
You're not counting the water lost through respiration. More of the body's water supply goes towards heating and hydrating the cold air during inhalation. Or cold-induced diuresis, which blocks the kidney's signals to retain water in the cold (it's why you feel the need to pee when you're in cold water).
That was mentioned above, in my previous post:
Quote:
Respiratory water loss goes up as temperature gets colder, but we are talking about mili-liters per hour....like a delta of 30 ml/hour. Not LITERS. So, that's an extra couple of tablespoons. 2/3rds of this effect occurs by the time you reach 32*F. It amounts to roughly 1 1/2 cups over a 24 hour period. Hardly worth writing home about.
For Moderate to heavy exercise, water lost to respiration is on the order of 60 ml/hr at room temperature. That goes up to 80 ml/hr at freezing, and only an additional 10 ml (up to 90 ml/hr) at -4 F. So, over a two hour run in the cold, one could expect to expire roughly 1/10th of a liter of H2O. If you want to say that -4F isn't -20, fine double it...that's excessive but ok. Still that's only 2/10th of a liter---just under 1 cup.
For CID...if you're not pee'ing while on the run, its not a concern. If you ARE, then there is an obvious clue that you are loosing water. A full bladder is roughly 1/2 liter, so you'd have to pee a couple times before its significant in dehyddration terms.
My point was NOT that there aren't cold effects. My point was that they are small (when compared to heat induced effects), and that the predominant contributer is, in fact, the SAME contributer as the heat induced effects....ie sweating. The only effect that is "invisible" is respiration loss, and that is not enough to be a concern. Sweating and peeing are obvious. If you are sweating enough to be a problem, your clothes will be WET, not moist or damp, WET. If you pee 5 times on a 2 hour run without drinking...yeah, that might be an issue to manage.
The effects in the cold are NO WORSE than the effects in the heat, and generally are MUCH less, and are easily detectable as either sweating or urination. Same as summer time.
Again, all this is easily manageable by simply tracking body weight before/after a shorter run...and deciding if that weight loss rate is enough of a concern for longer efforts in similar conditions. If so...put a martini in your flask and go for a run. :-)
