Andrewmc wrote:
I saw some tubing yesterday my wife had snd was wondering if I could rig something
Top idea
The master sprinkler shutoff valve at my house is buried at the bottom of a 1.5m deep x 10cm diameter PVC access pipe to protect it from freezing in the winter. In the Fall, we shut off the system and blow the water out; in the Spring we open the valve again. A long T-Handle "curb valve key" is used to access the valve.
One year, the 4-yo kid next door apparently decided that it would be fun to drop rocks into the PVC pipe. I go to access the valve and find that I can't seem to turn it. Check with a flashlight, and find that the valve is covered in rocks.
First, I tried to just vacuum out the rocks with a shop vac, but they were too heavy to get sucked up. So, I Macgyver'd a shop vac/duct tape/tubing tool and fished the rocks out one at a time as they stuck to the bottom of the tube via suction.
Congratulations on your rivet victory.
"100% of the people who confuse correlation and causation end up dying."
