gary p wrote:
Bigger rotor has more mass and can absorb more of the energy that is converted from kinetic to thermal during braking. Also has more surface area to radiate that thermal energy to the atmosphere. You go "big" to avoid overheating when the mass is higher and/or the likely use case is repeated or long, continuous braking events. In terms of braking force on a single stop where you're not approaching the thermal capacity of the rotor, it's a non-issue.
From testing sample and prototype brakes to see if they can meet CPSC standards, I can tell you that rotor diameter does make a difference. For these tests, I'm only doing single stops from 15mph on flat ground, not enough to get the rotors past warm. Going to a larger rotor often made a difference whether a brake would be able to stop in the required distance, especially with many of the cheaper mechanical calipers.
"I'm thinking of a number between 1 and 10, and I don't know why!"
