What came out of my P2-frame #thething
Some weird thing came out of my 2011 Cervelo P2 frame. Does anyone have an idea what it might be? I discovered and removed it while renewing the cables through the frame, but Houston do we still have a problem here?
I bought the bike new and assembled. Somehow 'the thing' must have been there all the time and I only noticed it after it must have broken off on the inside of the frame. It looks and feels like hard plastic. Maybe hardened glue or epoxy resin. One side is 100 % flat, the other as can be seen on the picture
Ideas and suggestions are very welcome solving the mystery.
Cheers, Gerard, NL
Next race probably St. Anthony's in St. Pete's
Re: What came out of my P2-frame #thething [GLinde] [ In reply to ]
The mold used to build up the carbon in a frame tube?
"i disagree with your analysis [or judgment], nevertheless you have the responsibility of moderating this board so i honor your authority to make the moderating decisions."
Re: What came out of my P2-frame #thething [klehner] [ In reply to ]
Bladder
Here I was expecting a pic of a small bolt or peice of plastic. That’s another little bike
Not sure what it is but you just saved yourself some grams. Free speed!
Re: What came out of my P2-frame #thething [lyrrad] [ In reply to ]
lyrrad wrote:
Bladder
This.
Louis :-)
Re: What came out of my P2-frame #thething [louisn] [ In reply to ]
louisn wrote:
lyrrad wrote:
Bladder
This.
Louis :-)
+1
Yup, that’s part of the bladder used in the moulding process. On higher end bikes they usually take the extra time to remove all of it to save every last gram; on a more intro level bike like the P2, not so much.
It’s not structural in any way, so as has been mentioned you just saved some weight.
Powered by: Hat Tip - the power of thanks
http://hattip.com http://locations.hattip.com
I think your P2 absorbed its twin while they were in the womb. You hear about that happening sometimes.
Re: What came out of my P2-frame #thething [davetallo] [ In reply to ]
Yes! That happened to Tyler Hamilton. I would suggest that your P2 should avoid any doping tests.
chapeau!
