lombardi3g wrote:
embarrassed to admit to another episode of overtraining - this time doing squats with an 85# barbell load on my back - I was sure my 3+ week break from lifting then dropping back 10# from a 95# load would cause no problem for a 61-year old, 158# wt. I think my form is good. Felt some pain on set 2 but decided to do set 3 ANYWAY! Then had to move furniture on the weekend.
If you only *think* your form is good, it probably isn't.
Doing set 3 was stupid.
Quote:
That was Dec 14 - 3 weeks ago. I rested for a week and then tried to resume light training (no weights - just short, easy swims, run, bike, and stretches). So when I do nothing for 2-3 days it almost disappears and when I run miles or climb 600 ft on the bike the soreness returns. It was difficult to sleep but if I avoid laying on my belly or back I sleep ok. I think it is just sore lower back muscles.
!!! STOP !!!
Quote:
I have a sprint Tri on March 16. Do I try a week of NO exercise or will including planks and stretches like cobra, downward dogs, inverted hamstrings scorpions and spidermans be helpful? So far they haven't cured me. What might be good rehab exercises?
TIA, Allan
Okay....here's my rule of thumb. You won't like it. It generally takes twice as long to recover from an injury as you spend injuring it and re-injuring it. So, you've spent the last 3 weeks NOT caring for your back, and continuing to reinjure it. Expect 6 weeks (more or less) to be back to normal.
Second rule. Don't screw around with load bearing joints and muscles (basically everything from your belly-button down. You can't just stop using them until they heal, which just makes it take longer. AS SOON AS you feel something, for the love of all things holy STOP!!! Don't ride the 20miles home, don't finish the last 5k of a run, don't do just one more set of weights.
Third rule. Never train with pain masking drugs (anti-inflammatory, Tylenol, etc). If you can't train without it, don't train with it. I'm not saying not to take these...just don't train if you need them.
(((NOTE: I am not a doctor. This is NOT medical advice. Just my long time experiences with similar injuries, and lessons learned from doing it wrong. ))) How to recover?
1. A week of NO TRAINING. No planks, no stretches, no SBR. Just stop.
2. But, bed rest is bad, too. Light, slow (2mph?....NOT A BRISK WALK), frequent walking is your friend. Start with maybe 10 minutes every hour or two. for pace, think....following your wife through the department stores. Gentle.
3. Alternating ice, then heat can often help ease the muscle spasms and pain. The ice freezes the spasms, the heat loosens things up. Ice first, heat last.
4. Try to keep your back straight. Sitting is usually bad. Standing or laying down is better. But, I always find walking better than standing still. When I lay down, I put a couple of pillows under my knees. Just enough to relay the lower spine.
5. Take Tylenol and/or ibuprofen/aleve for pain. Reducing the pain, reduces the spasms and tension, which allows things to heal faster.
If you aren't pain free after a week, continue above until you are. It may take more than one given how long you've let it fester and re-injured it.
Once you are ready to return to training. Start with the bike---ON THE TRAINER. Its the easiest on the lower back muscles. Just an easy 10-20 minutes. Think recovery spin. Do this for a few days, increasing the time by 5 minutes or so as tolerable. If that goes well. Try a short ride outside. if that goes well, add a short recovery swim. Again, progress over a few days as tolerable. if all that is going well...add in a short recovery jog. Extend as tolerable over a few days. See the pattern?
Assuming you are still pain free, at this point, you can begin to resume "training" at maybe 50% load...increasing by 10-20% per week.
Once you are back to full SBR (still no weights), you should consider a core mobility/stability development program.
Best case the above is probably 4 weeks. But, if you catch these things early, and don't push through the above can often be abbreviated into a week or so.
Before you return to weights (after several weeks of normal training with no pain), I'd suggest getting a session with a trainer to review your form and ensure that everything is PERFECT. Squats need to be PERFECT, not just mostly ok.
