Need bottom bracket compatibility advice & recommendations
Ok, so I just ordered 2 new frames and need to make sure I order the right BB for them. I will be using my SRAM Red Quarq DZero cranks that are BB30/BB386.
First bike is Felt IA1 Disc. This has BSA threaded 68mm bottom bracket shell. This looks fairly straightforward, FSA makes the linked below BB, as well as a ceramic one for $200+. Any other options I should be looking at?
https://shop.fullspeedahead.com/...hread-steel-bearings
Next is Felt FR1 Disc. This has BB386 bottom bracket shell. Does any PF30 BB work here? Any recommendations?
https://shop.fullspeedahead.com/...es/pf30bb386-bb-road
Strava I Instagram I Team Every Man Jack I
Re: Need bottom bracket compatibility advice & recommendations [Sean H] [ In reply to ]
The IA is threaded? I could have sworn it was BB30. If it's the latter and not the former then what you linked won't work. The good news is you can merely pressing in some BB30 bearings and run spacers to take up the space on the Red Quarq (I have the same crank on my Up and love it). Another solution, and one I might do for my Da, is this guy from bbinfinite
The second link you posted should work on the FR1. However, I'm not a fan of those solutions. I'm using a Wheels Manufacturing on the UP and pretty happy with that guy. Now, you could also run bbinfinite there too.
ETA: You're right. Felt's Website says it's BSA Threaded. It looks like they made a switch on the disc frames. That's cool. Yeah the link you posted will work and if you want options there are Wheels Manufacturing or bbinfinite
My YouTubes
Re: Need bottom bracket compatibility advice & recommendations [LAI] [ In reply to ]
According to this:
https://feltbicycles.com/...disc-triathlon-frame
It's BSA 68 threaded.
I'm shocked!!!
Re: Need bottom bracket compatibility advice & recommendations [jaretj] [ In reply to ]
Yup. That's what I saw too! It's awesome they made that change, but Felt's still using the same BB30 mold on the rim brake model.
My YouTubes
Nope, I think they changed to BSA threaded for all 2019 bikes.
And thanks for the links, I will prob go with the wheels manufacturing. I like the idea of threaded as opposed to pressed as well.
You're right. I looked at the 18 frame set model. Doesn't look like a rim brake frame set is offered for 19?
My YouTubes
I've heard they will offer an IA10 2019 frameset, so we'll see
