I’m usually the self proclaimed expert on garmin watches, but reciently got a HR strap that does both ant+ and Bluetooth, how do I know what the 935 is using to connect to the HR? Thanks
Re: Garmin 935 Ant+/Bluetooth question [triathlete37]
I have a Fenix 5 but believe the software is the same. I added a wahoo tickr HR strap a while back and the watch sets up two connections for bluetooth and Ant+. I wanted it to use Ant+ so dropped the BLE connection.
To check which connection you have go to Settings->Sensors & Accessories, select the HR strap you added and select About. It should display something like:
If you have BLE enabled it will appear as:
Ok, thanks, you an also check the battery level of connected devices by doing basically the same steps. Thanks again.
