New TriRig Omega brake issue
New brake just installed on the rear and the calipers stick shut when I apply the brake. I sprayed the upper area where the orange rollers are with WD-40 and that solved the issue for about 10mins but now it’s sticking closed again each time I apply the brakes. Have another on the front and it works flawlessly.
Any suggestions? Thx.
Re: New TriRig Omega brake issue [sailnfast] [ In reply to ]
Did you replace your brake cables and housing?
try applying some park tool grease instead. WD40 is more of a cleaning agent
Swap front and rear and see. I suspect cable though.
Re: New TriRig Omega brake issue [Benv] [ In reply to ]
Yes brand new housing and cables.
Re: New TriRig Omega brake issue [s13tx] [ In reply to ]
Don’t really want to go thru the hassle of swapping. What could be the issue with the cable?
Re: New TriRig Omega brake issue [Yeti racer] [ In reply to ]
Used the WD40 as I thought that might clean it out a bit, will try grease and see if that helps. Thx.
Contact Tririg - they are super helpful and I am sure they will solve your problem quicker than any forum.
Re: New TriRig Omega brake issue [CG99] [ In reply to ]
CG99 wrote:
Contact Tririg - they are super helpful.
Thanks for the good laugh!
Re: New TriRig Omega brake issue [DFW_Tri] [ In reply to ]
I agree. He has been quite responsive to me.
The biggest issue with the cable would be a kink, a bind, etc. take the cable out at least and see if it move completely freely
Always happy to help. Just email support@tririg.com, and sending pictures and/or video of the issue would be great.
TriRig.com
Re: New TriRig Omega brake issue [iamuwere] [ In reply to ]
I double agree...I had an Omega pad holder that had a screw freeze and Nick emailed back right away letting me know he sent a replacement holder out via Priority Mail.
