3T Aura Internal Routing Di2
Trying to fit some 9150 climbing shifters in the cleanest way on my bars.
The cable that they come with is just a little too short so will need to extend them somehow.
Was hoping to find a way of using a single JC41 junction box, with a single extra bit of cable but try as I might, I can’t seem to loop a cable through the stem clamp area and not sure it’s even possible.
Help!
Re: 3T Aura Internal Routing Di2 [The Red Baron] [ In reply to ]
Try looping derailure cable through the part. If it can go through you should be able to pull the wire through using it as a guide. I just did a di2 build of my SC and used that method to save time. Tape the wire to the cable and gently pull it through. If the derailure cable can even go through the bars your outa luck
I think this answers your question
