Just did European Beach Mountainbike Championships in the Netherlands earlier today. It was cold, wet, really, really hard and fun. It was even sleeting a bit at one point. Many of the bikes are really tricked out with special forks, handlebars and nearly all the bikes (except mine) had big, slick tires. I learned that those tires are real helpful in letting the bike glide over the sand instead sink in. For those with some experience in this type of racing, can you recommend some good, affordable and durable tires for a 29er mountainbike that will work well for beach racing? There is another race here in January so I’d like to put em on the Christmas list. Thanks in advance.
Re: Beach Mountainbike Racing Question. [jsmith]
Sounds like you want something like the Bontrager XR2 in 2.6” width if you can get it to fit. The Schwalbe “Big One” is another option if you can find them.
Continental Speed King or Compass Antelope Hill if you really want to go fast
Agreed on the Schwalbe Big One for tires. Standard issue f/r on the Koga BeachRacer Pro though I think Koga used to put Thunder Burt on for the front tire
https://www.koga.com/en/bikes/race/collection/beachracer-pro.htm?frame=H
When I was doing beach races I really liked the Notubes Raven 2.2 (with sealant) on 1.2bar (80kg).
Re: Beach Mountainbike Racing Question. [ols]
I believe you're correct, Thunder Burt up front and Big One on the back. I run Thunder Burts for gravel, they're super fast on pavement too. I've only ridden them on short stretches of sand, but they were ok on soft sand.
Schwalbe Big One or Vittoria Tattoo light. The big one's are better but I race the Tattoo lights because they are more affordable ;)
Most import is tire pressure (tubeless), try what's best for you without hitting your rims against rocks.
Team Zoot Europe
Team Zoot Europe
Re: Beach Mountainbike Racing Question. [Kaniman]
Doing that race again this weekend. Got a set of tattoo lights on the mountain bike now. How low would you suggest running the tire pressure?
It looks like this is mostly on the well packed wet sand, or do they go into soft sand sometimes as well?
Wonder if an even fatter tire at low psi might be the best?
Most the well packed sand near the shore but you have to go up into the soft stuff for a fair amount at the start and each of the turns (2 loop course so 4 times). That is one place where you can really lose the pack.
