trailerhouse wrote:
warlockuy wrote:
Thank you
use best bike split, but it is half dreamy the numbers it gives.
or some data I put wrong
hehehe
thanks
You can use bestbikesplit to reverse engineer your CdA (coefficient of drag): create a BBS course or use an existing course derived from your most recent race (export power file as gpx). Plug in your bike numbers as accurately as possible (weight, equipment, tires etc.), get weather data from the date of that race, put your actual power numbers in from the race and then play with the CdA # until you get your actual race time. Save that number and run a simulation for a different course. Should now give you a fairly accurate estimate.
Very very thanks
Because he did not give me the real time
But now with your explanation of how to use it I will try to do some field test
very thanks
