I wrench my own bike due to my proximity to LBS
I just replaced my Trek SC BB90 bottom bracket (SRAM Force 22 crankset) after 4 seasons. IM Louisville was the final straw. An LBS did install the crankset a few years ago
Drive side has 24mm ID and non-drive side has 22mm ID.
When I pulled my crank, I noticed there was no dust cover on drive side. Is this normal?
I pressed the bearings with no issues. The non-drive side bearing has a built-in spacer reducing ID to 22mm. The dust cover that came with the BB90 replacement kit does not fit around this spacer/ ID reducer. Do I just order a dust cover that fits this bearing? Is there I am just running without a dust cover now as I am all trainer during the off-season
I have scoured the internet, this forum and you tube for an answer and cant find one
Thanks
Thanks
