After two years of not leaking like other 735XTs, mine has started to die. Seems like the battery is the issue causing a dodgy display. At full charge everything is fine, but after 30 minutes the display struggles to render. Unit is two years old, so outside of warranty.
Garmin have offered a replacement unit for $100. I’ve not had much luck with Garmin products, which I was hoping I could put everything into Garmin Connect. I held off getting a 520 Plus as I’ve started to doubt Garmin.
Should I get the replacement? I do miss a barometric altimeter over a GNSS altimeter. I like the daily tracker part of the 735XT...
I’ve used Suunto’s Movescount. Not used Polar’s website. Anyone got any thoughts? Recommendations?
