Just did an Oly race, and for the first time I managed to cut the gap between my pool swim paces and OWS paces to essentially zero, meaning for the first time in my tri career I didn't swim slower by 7-10 (or more) sec/100 in OWS compared to what I'd expect in the pool. Finally dropped under 1:30/100yds for the Oly OWS, compared to my normal 1:40-1:52/100yd paces in all my other races.
Note I'm comparing times using my self-recorded Garmin recording of the swim leg where I manually start/stop the swim segment, as I've found that races can vary quite a lot with their so-called 1500m race distance. (I can confirm that the GPS trace isn't totally wacky on the map.)
This and my other races were also loop courses that start/stop in the identical spot so you can't get much of an unfair one-way current advantage.
While I definitely felt stronger and far more confident during the entirety of this race swim, I was definitely NOT in my top swim form compared to my prior self. The one thing that I did do differently though, is that I took pool sighting practice very seriously in the 4-5 wks prior to race day, with increasing sighting added in until I was doing entire workouts sighting every 3rd-5th cycle 2 wks out from race day. Was annoying for sure at first, but got used to it quick.
I can't help but feel that sighting practice made a big difference for me - it really FELT that way on the swim, with a lot of confidence for once even with a ton of bodies in the start. I didn't have the luxury of doing true OWS practice at all before race day, but I felt that pool sighting was a pretty good simulation of it, and might even be better if you have better pool than OWS access.
Any reason why sighting practice is rarely mentioned as a key piece of OWS performance for the big pack of AGers that are constantly bemoaning their status in the MOP or BOP on the swim?
