You can get a SRAM 11-28 11sp cassette which has a 16 cog. It's pretty sweet... my favorite cassette.
The 11-25 cassette has a 16 but not the 28 that you probably want but it gives you the "fun" 11 gear, and on a day like 2018 Kona, the right gear for a good 30 minutes of the ride.
The 12-28 cassette has a 16 but not the 11, but it does have the relief 28 that would be more critical on a higher wind day (especially if you want to preserve run legs by spinning more). Does this make sense?
What's your CdA?
Russ Brandt wrote:
If we are talking about 11 speed cassettes, the Shimano 11-28 skips the 16 gear. Many other wide ranging cassettes miss the 16 gear to. I am saying that I think the 16 is critical for typical cruising power and cadence on the Kona course. Again, in my case I was in that gear for 29 minutes so that is a good chunk of the course. If I didn't have the 16, that means I would have spent 29 minutes in the 15 or the 17, either of which are doable, but just not the perfect gear to be in for those times. The 11-25 cassette has a 16 but not the 28 that you probably want but it gives you the "fun" 11 gear, and on a day like 2018 Kona, the right gear for a good 30 minutes of the ride.
What's your CdA?
