don't get me wrong, your position is fine... it was just the first instinct that popped into my head (and one other fitter) when I saw the two static pictures. You seem ever so slightly "slack". I'd like to see how you reacted to being more forward, from all three aspects of a fit... comfort, power, and aerodynamics.
Regarding saddle, you're describing a quite common situation regarding the ISM. I'd use Body Glide instead of butter as it's thicker and will last longer after a swim. As for the Mistica, I don't seem to have a problem personally with any soft tissue contact as I'm contacting pubic bone on the two ends of the Mistica.
It's an art form how to properly sit on a saddle, for each saddle. Each one has its own optimal contact point, for *each* one of your position changes. I'd give it another try.
damon.lebeouf wrote:
ericMPro wrote:
no you were right... I'd be interested to see what bringing him forward and adding reach would do. For long course, I'd also be curious to see how he reacted to different saddles than the one he's using.
eric,
im interested to know your reasoning on looking at different saddles.
i tested a few different saddles at the fitter and landed on the ever popular ism saddle. at around an hour (with no chamios butter) i get some pretty good chafing going on between the boys and my inner thigh. i tend to move around on the saddle some to try and get comfortable. with butter its not much of an issue, but in reality you cant rely on that after a swim.
i tested out the fizik tritone during initial fit process. i really wanted to like that saddle but you perch way out on the front of that sucker and it just digs into your perineum. ive been thinking about renting one again for a longer term test and see if i can get used to it as it would eliminate the issue im running into.
Eric Reid
AeroFit |
Instagram Portfolio Aerodynamic Retul Bike Fitting
