Cervelo P2 (2014) FD hole on seat tube
For the life of me I cannot find what's best to put in the circular hole on the seat tube just above the BB where the cable comes out for the FD. Most pictures have a crank so it's hard to see it clearly, but I have seen an inserted cable stop (that I can't seem to find online), normal cable housing, and just bare cable. I've read stories of cables ripping into frames, so would like some protection for the frame and cable. Is there a specific Cervélo cable stop like the ones on the top tube or should I use normal cable housing/teflon tubing to protect it?
Eggnog is why I train.
Re: Cervelo P2 (2014) FD hole on seat tube [dreggnog] [ In reply to ]
I just run a piece of housing all the way through on mine.
Did you look here?
https://www.excelsports.com/search/?keyword=Cervelo
Or do you have a local Cervelo dealer?
If not try asking Trent at the TriShop in Plano Tx or Julie at Pacific Cycling and Triathlon in Stamford, CT as they are Cervelo dealers, lurk around here, and may be able to help.
Re: Cervelo P2 (2014) FD hole on seat tube [DFW_Tri] [ In reply to ]
I did look on Excel Sports, which was great for the cable stops for the top tube and chainstay, but nothing on the seat tube. Unfortunately no Cervélo dealers near me and the two in Indy I went to during a race weekend didn't know what to put. If housing works, that seems simple enough for me, thanks!
My 2015 P2 came with just bare cable there (which I thought looked a little strange). No issues though with rubbing so far.
Housing liner works, but you don't really need to do anything. The cable is not likely to saw through the frame.
Re: Cervelo P2 (2014) FD hole on seat tube [beston] [ In reply to ]
You can find nearly everything cable widget parts at Jagwire. You can ID the part you want, and then find an online retailer who sells that Jagwire part.
Team Zoot-Texas, and Pickle Juice
My 2012 came with a 3 or 4 inch length of inner cable liner like was posted above.
